New Products
Laser Cutter Boasts High Throughput
Thursday, May 1, 2008
Mitsubishi Laser, through MC Machinery Systems, Inc., Wood Dale, IL, introduces the next generation of its LVPlus laser-cutting machine. The new LVPlus combines several new performance-enhancing features and its flexible automation is versatile and expandable, with several options to maximize throughput based on consumer needs.
The machine’s new 40CF-R resonator technology reduces the rise time and fall time of the square-wave pulse. This provides more consistent beam power during the cutting process and delivers a more brilliant and consistent edge quality, according to company officials. Additionally, the uniform low-current discharge provides low-power stability for improved micromachining and etching.
Its new Brilliantcut technology, which can produce a cutting-surface roughness equivalent to the typical machined finish, provides optimal processing conditions, reduced taper and reduced discoloring on the heat-affected zone.
Also, new Jet Pierce technology decreases part time by allowing material to be pierced faster and more aggressively during small-hole processing. Improved height-sensor hardware gives the machine twice the tracing ability of the original machine.
Mitsubishi’s Diamond-Path technology maintains consistent beam quality by using a constant beam-length system. It provides cutting stability at speeds to 1150 in./min. across all processing areas.
MC Machinery Systems, Inc.: 630/616-5920; www.mitsubishi-world.com
See also:
