Compact Side-Transfer System
March 1, 2008Comments
TTS Automation/Sander Automation GmbH, Barrie, Ontario, Canada, will showcase the new HST side-transfer system that is more compact then conventional side-transfer systems. It features a patented, efficient scissor-arm design that allows higher speeds and throughput in pressroom automation.
Designed with the user in mind, all moving parts are within the equipment and the press-bed area, allowing the operator to see all functions of the tool, grippers and in-die automation.
TTS Automation also provides standard through-the-window transfer systems in 2D and 3D configurations.
See also: X
There are no comments posted. Pressroom Automation
Brad Kuvin Monday, October 31, 2022
No Choice but to Automate
Thursday, September 29, 2022
New Presses for Blanking, Progressive-Die and Transfer Appli...
