Hot off the Press
Fabricator to Install High-Speed Tube-Cutting Laser
Friday, January 19, 2007
Bauer Welding & Metal Fabrication, Inc., St. Paul, MN, has purchased a model LT712 LaseerTube cutting machine from Italian supplier BLM Adige (BLM Group USA Corp., Wixom, MI), a 2500-W unit capable of cutting round tubing to 6-in, OD and 4-in. square tubing. Bauer, which provides tube-bending, fabrication and welding services, operates draw-, press-, mandrel- and roll-bending equipment, and houses robotic welding and high-definition plasma-cutting cells. Learn more at www.bauerweld.com.
