Hot off the Press
Double-Loop Slitting Line Headed to Berlin Metals
Friday, May 5, 2006
To boost its processing and distribution capabilities for tin-mill products and stainless-steel strip, Berlin Metals LLC, Hammond, IN, has ordered a 60-in.-wide double-loop coil-slitting and automatic slit-coil packaging line from Braner USA, Franklin Park, IL. The line, which accommodates rapid tool changes, can operate at speeds to 1200 ft./min to generate coil ODs to 72 in. It was designed to process surface-critical coated and bare carbon steel, 300- and 400-Series stainless steels, and aluminum alloys from 0.005 to 0.075 in. thick.
