Program Multiple Conveyors with Dual-Input Interface VFD Motor COntrol
November 1, 2007
For customers who need a quick and easy control solution for their application, officials from Dorner Mfg., Hartland, WI, say its new Dual Input Interface VFD motor control is the perfect answer.
The motor control comes ready to install out of the box—no wiring required by customers. The control unit is designed as a plug-and-play, which allows customers to connect it to the conveyor system, plug in the accessory that best meets the specific application and turn it on.
Ideal for small- to mid-sized material-handling projects, the unit is ideal for indexing applications. Other uses include changing conveyor-belt speed and powering a variety of add-on accessories, such as photo eye or pushbutton kits.
Dorner Mfg. Corp.: 262/367-7600; www.dorner.com
See also: Dorner Manufacturing Corporation
