Red Stag Earns Patent for Cushion-Control Software
June 1, 2008Comments Red Stag Engineering & Automation, Inc., Waupaca, WI, received copyright patent registration for software that controls an intelligent hydraulic cushion for mechanical presses. To optimize control of binder pressure, the software allows for programming of stroke and hydraulic force of each cushion cylinder. Each parameter can be changed more than eight times as the press ram cycles from the 3 o’clock to 6 o’clock position at production speeds.
Facilities
See also: Red Stag Engineering & Automation
Technologies: Tooling
There are no comments posted.Engineering the Outcome: Tool Steel by Design, Not Default
Manuel Resendes September 25, 2025
ToolingTips for Maximizing Tooling Life
Thomas Vacca Friday, September 26, 2025
Introducing the MetalForming Tool & Die ebook
Wednesday, January 15, 2025
