Color-Coded Die Springs
March 1, 2008
Color-coded die springs
Wilson Tool International, White Bear Lake, MN, through Impax Tooling Solutions, will display its SpringMax line of die springs, engineered to provide the high tensile strength required to withstand heavy load demands and constant high-speed deflections experienced during stamping. Spring ends are precision-ground and shot-peened to improve compressive strength and fatigue life. The result is extended trouble-free performance, reduced spring breakage and downtime, and consistent quality, according to company officials. The die springs are protected by a long-lasting vinyl coating that resists corrosion and chipping.
www.wilsontool.com
Industry-Related Terms: Die, Tensile Strength
See also: Impax Tooling Solutions, A Div. of Wilson Tool International
Technologies: Tooling
