Sko-Die Buys Fineblanker and Stamper Harig Mfg.
June 1, 2016Comments
Sko-Die, Inc., Morton Grove, IL, a manufacturer of custom steel laminations and heavy-gauge metal stampings, has acquired the fineblanking and metal-stamping business of Harig Manufacturing Corp. Harig makes precision parts for the automotive, appliance, power-tool, aerospace and controls industries.
Harig’s fineblanking and stamping operations have been incorporated into the Sko-Die Morton Grove facility, with recently installed equipment including four Feintool fineblanking presses (two 160-ton and two 250-ton). These presses can run parts from 0.060 to 0.375 in. thick, circular parts to 5 in. OD and straight parts to 8 in. long. Two deburring systems also have been moved into the facility, and two of Harig’s experienced operators have joined the Sko-Die staff.
Technologies: Bending, Cutting, Stamping Presses
There are no comments posted.Robotic Press Brake Cell Success Part of Patient Automation ...
Lou Kren Monday, February 26, 2024
Press Brake Efficiency
Brad Kuvin Friday, January 19, 2024
Building Bend-Angle Accuracy into Press Brake Design and Con...
Tuesday, October 31, 2023
