Bilsing’s PFG Series Vacuum Cups Suited for High-Speed Applications
February 17, 2021Bilsing Automation’s new silicone-free PFG treaded vacuum cups deliver optimum gripping force and the flexibility to adjust to uneven formed parts or parts with edges in steel and aluminum, as well in non-metal parts. PFG-series cups feature an oil-displacement lip on the outer edge and a brake-rib arrangement that provides for oil and dirt dispersion for optimum gripping ability. Featuring a thin, hard shape, the cups also resist deformation.
Vertical stroke holding capacity is 80 lb.; lateral force capacity, 43 lb. Bilsing rates the cups for continuous use at temperatures from 86 to 212 F, and for short-term use at temperatures to 257 F.
Weighing only 2.6 oz with a one-part body design, the PFG cups are easy to exchange. And their single-body feature means less damage to metal sheets as compared to other designs. Order them in round or oval shapes for use with pin or ball connection adapters.
See also: Bilsing Automation North America
Kuka Wins Mercedes-Benz BIW Production-Line Automation Contr...
January 29, 2021
Bilsing Debuts Servo-Driven Carbon-Fiber T-Beam for High-Spe...
September 25, 2020
Destaco Updates its 800 Series Manual Clamps, Debuts Front-M...
Thursday, May 26, 2022
