3D-Printing Veteran
Harbec entered the additive-manufacturing (AM) arena about 25 years ago, according to Keith Schneider, its general manager, bringing in a machine for prototyping to supports its plastics division.
“Back then,” he recalls, “when making a production tool for injection molding, CNC machining was the only way to produce prototypes before building the tooling, an expensive and time-consuming process. Bob (Bechtold) sought an alternative, and 3D printing of prototypes was the alternative.”
Today, Harbec 3D prints a variety of material, using two EOS machines for metal alloys, and Stratasys and 3D Systems units for plastics, along with some smaller desktop printers. Delivered to Harbec in 2005, a metal-part-producing EOS M 270, recalls Schneider, was one of the first such machines installed in the United States.
“We didn’t know how to use it,” he laughs. That recollection matches with other early adopters of the technology, back when reference material and user experiences to draw on were in short supply. “We had to dig in and for the most part learn on our own how the machine (using selective-laser-sintering technology) really worked and how to process materials. Even today, 3D printing is as much an art as a science—building layouts, editing parameters and getting the properties that we want. While base parameters that work for most applications are available, figuring out the rest is the secret sauce.”
On the metal-AM side, Harbec produces tooling inserts to support its injection-molding operations, as well as parts for outside customers across a number of markets.
“Defense and aerospace have really taken off for us,” Schneider says. “We perform some volume production, meaning 200 to 300 parts per year, for aerospace. That production level fits metal-printing machines very well.”
Finishing Inefficiencies Addressed
This direct-metal-laser-sintering machine builds parts that route to an adjacent surface-finishing machine at Harbec. Simple installation and quiet operation make the finishing-machine’s location ideal, according to Harbec officials. |
Finishing operations can represent a huge bottleneck in the 3D-printing process when creating parts, especially metal parts. Unfortunately, the term 3D printing has fostered the idea that the process is as easy as using an ink printer: Simply “print” a part and off you go. As we have come to know, there’s so much more to producing parts via AM, and much of that involves the meticulous finishing process. Adopting the latest finishing technology is a no-brainer for Harbec, which also rides the leading edge on so many other processes and technologies.
“The biggest misconception in additive manufacturing is that you can just print a finished part,” says Schneider. “A lot of companies using 3D-printing equipment don’t really look at finishing. The industry has to overcome that and get on board with the finishing end of things before we really progress.”
Schneider sees a part as halfway done after printing.
“We CNC-machine 85 percent of the parts that come off of our machines, just for accuracy,” he says. “Tolerances may be ±0.005 in. coming out of the machine, and our aerospace customers, for example, want less than ±0.001 in. So initially we look at the geometry and figure out exactly what areas must be machined to tight tolerances. We add additional stock to those areas. And, if we have surface-finish requirements, then we plan on tumbling the parts to meet those requirements.
In tune with the importance of rapid, accurate finishing, in 2015 Harbec brought in a prototype finishing (tumbling) machine from PostProcess Technologies (www.postprocess.com), after meeting the company’s founder, Daniel Hutchinson, at an AMUG conference.
“We found out that Daniel was from nearby Buffalo, and we were looking for finishing equipment, though not sure exactly what kind,” Schneider recalls. “We met a number of times and brought in one of PostProcess’ first surface-finishing machines, almost a prototype model.”
Edge rounding was Harbec’s biggest concern with tumble finishing.
“Many equipment manufacturers can deliver a surface finish, but we would end up with washed-out part features and broken corners,” says Schneider. “A machine’s energy would be focused on corners as much as everywhere else.”
Equipment Delivers Advanced Post-Processing Capabilities
With what can be best described as smart technology, PostProcess’ machines employ algorithms that control energy distribution. The algorithms work in combination with the chemistry of cleaning agents, the material properties of the cleaning media, and hardware that enables the entire system to function efficiently and quietly.
In 2017, Harbec brought in a new PostProcess Milli machine, incorporating newer technology and designed to practically eliminate noise. Harbec stations the machines directly next to its metal printers. During 3D Metal Printing’s visit, we saw it positioned adjacent to an EOS M 290 direct-metal laser-sintering system. Only a 120-V electrical hookup is required to power the Milli, and like all of PostProcess’ finishing equipment, the machine at Harbec rests on coasters for simple movement to wherever needed. The finishing machine’s proprietary AutoMat3D software computes cycle times with detergent dosing based on the software’s preprogrammed recipes, built from hundreds of benchmarked parts of almost every 3D-print material on the market. The Milli features a noise-suppression enclosure and single-button operation. It is self-contained, with premixed chemicals poured in, parts added, and the machine set to its programmed cleaning regimen with chemicals dispensed into the cleaning media automatically. Then, finishing can be forgotten as operators return to printing or other duties.
In operation, the machine combines vertical motion with PostProcess’ reportedly environmentally friendly consumables to achieve the required surface finish. The Milli, ideal for larger parts with its 28 by 10 by 12-in. work envelope, can employ a divider to run two smaller-envelope sizes with different abrasive media.
PostProcess, claiming to be the first and only provider of automated and intelligent post-processing for 3D-printed parts (see Smart Finishing Takes Shape subhead), estimates that using its technology can provide cost savings of 90 percent as compared to full-manual-labor finishing, with an average ROI of 17 weeks.
Employing the automated surface-finish technology required only a short learning curve, according to Schneider.
Located adjacent to a metal-AM machine, this surface-finishing unit smartly and quietly does its job. |
“Canned programs within the machines enabled us to get started quickly,” he says. “We plugged in the machine, gave the operators recipes for the solution media based on the metal alloys to be finished, and let the machine do the work. With set programs, it is simple to get up and running. And when we were comfortable we could go in ourselves to optimize the finishing programs for our particular materials and needs. Custom recipes then are saved for future use.”
“Differentiating PostProcess’ machines, other equipment not specifically designed for 3D printing and these types of parts would have rounded corners and washed-out part features,” Schneider says. “The surface-finishing technology we now have does a great job of creating homogeneous finishes without breaking down the corners.”
Now, while cycle times for finishing vary based on part geometry and materials used, the process does not hold up Harbec’s manufacturing processes in any way, reports Schneider.
“3D printing is not fast when producing metal parts, so we may have three or four days before the next build is ready for finishing,” he explains. “If finishing takes 4 or 5 hours, we have no bottleneck.”
Before obtaining the new post-processing technology, Harbec performed “a lot of hand finishing, and everyone hated it,” says Schneider, with a chuckle. “Or, we would intend to machine-finish the entire part and just print near-net on 100 percent of the dimensions, followed by CNC machining. That’s still an option, but placing parts in the surface finisher and walking away is a much-less-expensive option.
“Full machining of a part limits possible geometries, especially internal geometries,” he continues, “so we have to consider that in doing the cost analysis on a part and how best to produce it.”
Harbec Tailors Processes to Customer Needs
Analyzing various methods for producing a part, stresses Schneider, is one area that sets Harbec apart.
“We work with metals and plastics, employ 3D printing, offer injection molding, and have a huge machining department, so we can look at options for our customers and not route them one way or the other just based on the process,” he says. “We can take different routes based on what works best and what is most efficient and cost-effective for the customer. We are open-minded with projects. What’s the best fit, what offers the best lead time and what are the customer requirements? We can pick from a variety of options to achieve all of that.”
Paralleling its flexible approach to customer needs, Harbec cross-trains its employees and can shift resources between processes as required.
“If we are slow in our CNC-machining departments, our machinists can build molds for injection molding,” notes Schneider. “And, because 3D printing lends itself to prototyping on the front end of a project, we can we feed that prototype work into our production molding or production machining. Our processes are very complementary.”
Environmental Initiatives Unique Among Manufacturers
It’s clear that Harbec readily welcomes technologies and processes that can deliver better options for its customers. As hinted at earlier, this approach is part and parcel of the company’s culture—unique among traditional manufacturers and fostered by Bechtold’s long-time embrace of innovation. This includes environmental awareness, which began for him when he installed a windmill at home in 1980.
Today, two onsite windmills provide for 60 percent of the facility’s energy needs, according to Schneider. And, the company reportedly was one of the first in the world to install a combination heat/power plant powered by microturbines. Here, as explained in a Rochester City Newspaper article, generators burn natural gas to create electricity, with steam produced during the process used for plant-wide heating and air conditioning. This provides another 20 percent of the company’s required energy. The remaining 20 percent—only via carbon-free sources—is purchased from the grid. To offset Harbec’s carbon emissions and those of company vehicles, the company purchases carbon offsets.
Conservation does not end there, however, as Harbec, through water recycling and rainwater retention, relies on municipally supplied water only for handwashing and drinking.
For his part, Bechtold, who once sought funding and acceptance of environmentally friendly initiatives based on a green philosophy, found much greater success pitching its real economic benefits.
“None of this started for marketing purposes, it was just Bob Bechtold’s passion,” says Schneider. “He’s been at it for a long time, and sustainability has picked up steam, so to speak, so we can talk about it and point out its financial sense.”
Following years of interrogating radar systems for the U.S. Navy in addition to a background in engineering and additive manufacturing, Hutchinson, PostProcess Technologies’ founder, president and chief technology officer, had an idea. Why not interrogate 3D-printed parts to better perform critical yet often overlooked post-processing? While design and build have garnered considerable attention during the ascension of AM, post-processing mostly was stuck in the past, with manual finishing—a 150-yr.-old task—the most common route for newly printed parts. According to the company’s own research, in more than 95 percent of cases, printed parts have supports to be removed, and more than 60 percent require surface and/or other finishing. Seeing that labor-intensive manual finishing could be transformed via technology and automation, he got to work and in 2015 PostProcess was born.
Traditional finishing operations may house labs of employees, all with different skill levels, performing the somewhat mundane job of hand sanding. Companies may spend much time and money to recruit, train and retain these employees, and still, from part to part and batch to batch, finishing results will vary.
In developing the company, Hutchinson saw the need to educate the 3D-printing community on his belief that AM is an integrated process with design, build and post-print intertwined. By taking into account each of these three facets along with the others, a better total project outcome may be possible. Focusing strictly on AM parts and envisioning an integrated process, Hutchinson identified a culture that would drive machine development.
“Culture, machines, software, consumables—these four set us apart,” he says.
Last September, PostProcess Technologies moved into its new Buffalo headquarters, which includes expanded space for the company’s Finish3D lab. The lab houses R&D, customer-benchmarking and training activities, and offers product demonstrations.
In its facility, the company develops, refines and sells a suite of products, including support-removal, surface-finish and hybrid machines in various sizes, as well as wastewater-treatment technology. Key to machine performance is development of proprietary software that takes into account material properties, part geometries and finishing requirements to optimize agitation intensity and direction as well as the introduction of detergent.
“Our machines work in a strategic way, knowing that the part must end up a certain way,” explains Hutchinson. “Along the way, the algorithm reroutes the process to account for fine features and other part attributes. Our database of properties, created from hundreds of thousands of benchmarked parts, gives us the information to create these algorithms.”
Cleaning solutions and abrasive media can be selected to match the given materials and requirements. Together, these developments represent a first in finishing technology for 3D-printed parts, according to company officials.
Works Closely with Manufacturers
Given its integrated-process culture, PostProcess often advises manufacturers on design and build issues that can affect post-processing, according to CEO Jeff Mize.
“We can make suggestions that won’t change the function of the part, but will increase the efficiency of finishing,” he explains. “Often times, a metal part may have more support than is needed. We can recommend perhaps a change in orientation that requires fewer supports and makes building and post-processing more efficient.”
The company’s equipment for removing the supports uses proprietary technology to check material density—in many cases, material density differs across supports and across parts—and remove supports while leaving the part intact.
Other technology enables cleaning of internal geometries and management of wastewater, which has proven popular with manufacturers, according to Mize. Despite all of the sophisticated high technology, the machines are simple to install, program and operate, according to company officials, and deliver dependable uptime while producing consistently post-processed parts no matter the material. 3DMP Industry-Related Terms: Abrasive Media,
Abrasive,
Alloys,
Center,
CNC,
Draw,
Edge,
Hardware,
Lead Time,
NC,
Point,
Prototype,
Run,
SurfaceView Glossary of Metalforming Terms
See also: PostProcess Technologies
Technologies:
