Resolving Splitting in Stretch Flanges and Cracking in Compression Flanges­—Part One
November 28, 2025
Splitting and cracking in a formed metal flange is one of the more common part defects faced by metal stampers. A split or a crack renders the part basically useless, and in most cases the part ends up being discarded as scrap. Here we’ll discuss tension and compression failures and explain a few of the potential causes and solutions.
Defining Two Flange Types
Fig. 1Flanging simply can be defined as bending on a curved axis. The two basic styles of flanges (Fig. 1): tension (stretch flange) and compression (shrink flange). During the forming of a tension flange, the blank edge distance increases, which results in the sheet metal being stretched into a greater length of line. This results from the concaved shape of the bend. Naturally, as the sheet stretches it becomes thinner. If it thins too much it will fail and split. We easily can identify a split because there will be thinning at the point of failure. The split typically originates at the blank edge where the greatest amount of stretching has occurred.
Fig. 2During the forming of a compression flange, the length of line decreases due to convex curvature of the part. This essentially means that the metal is being squeezed together rather than being stretched, which may cause wrinkles or, in many cases, thickening of the sheet. Failures occurring in a compression flange are cracks. In other words, splits occur due to excess localized tension and cracks result from excess localized compression. We can identify cracks because there typically is no thinning of the sheet at the origin of the defect (Fig. 2).
Strain Basics
Mitigating the failure—a split or crack—requires understanding the effects of strain, simply defined as the permanent deformation of the sheet metal. There are two primary types of strain: tension strain and compression strain. In other words, we can do only two things to a metal sheet: stretch it (tensional strain) or squeeze it (compressive strain).
Every time we deform a piece of sheet metal beyond a mechanical property known as its yield point, where we’ve made a permanent shape change, the sheet will work harden. This work hardening, also referred to as strain hardening, varies in severity based on the type of metal alloy. Grades used in structural safety stampings for motor vehicles, for example, work harden extensively, while others may work harden less severely.
For example, if we bend a piece of metal wire back and forth multiple times, eventually it will break. The number of bends required to break the wire varies with the type of metal alloy.  The same principle applies to tension and compression flanges.
Stress Basics
Strain results in stress—the force per unit area generated as a result of the deformation of the sheet metal. Trapped stress causes parts to twist, bow and warp, and results in a loss of part flatness.
Certain types of metal alloys, especially high-strength grades of steel and stainless steel, work harden extensively during deformation. If the number of forming operations is excessive or the material is extremely prone to severe work hardening, the part may become brittle during the deformation process. When the load is relaxed or when forming has stopped, the sheet wants to decompress. Think of it like a sponge: When you squeeze and then release it, the sheet wants to decompress. If it does not have any remaining stretchability due to its excessive work hardening, it will tend to crack. Needless to say, one of the main contributing factors to cracking is the material type and thickness being formed (Fig. 2).
The key factors contributing to cracking and splitting:
  • Material type and thickness
    • Mechanical properties
    • Chemistry
    • Sheet metal cleanliness
  • Part shape
    • Compression/tension severity
    • Flange height
    • Radii
  • The process (die geometry) used to make the feature
    • Number of forming operations
    • Part-edge condition
  • Lubricant type and application
  • Forming speeds, and the heat generated during forming
  • Time between forms.
In part two of this series on flange splitting and cracking, I will discuss all of the above-listed variables and factors, and explain how they affect the outcome. Until next time … Best of luck!  MF
Industry-Related Terms: Alloys, Bending, Blank, Curvature, Edge, Flange, Forming, Scrap, Stainless Steel, Thickness, Twist, Work Hardening, Forming, Forming
See also: Dieology LLC
Technologies: Management, Materials, Quality Control
