Live Five-Axis Waterjet Cutting Demonstrations
October 1, 2015Jet Edge, Inc., St. Michael, MN, performs live abrasive waterjet cutting demonstrations on its Edge X-5 five-axis waterjet system with Aquavision Di control and closed-loop filtration system. The waterjet manufacturer also shows its new, economical Boss-Cutter three-axis waterjet system, new 55,000-psi, 30-hp iP60-30 waterjet intensifier pump and X-Stream pressure intensifier pumps.
The Edge X-5 cuts precise taper-free parts from virtually any material, and is capable of cutting sophisticated 3D parts such as impellers and bevels to 50 deg.
See also: Jet Edge Waterjet Systems
Technologies: Cutting
