seen at fabtech
High-Performance Laser Cutting for Tube and Pipe
December 8, 2025Comments
At FABTECH 2025, Mazak Optonics Corp. showcased the FT-250, the company’s latest addition to its lineup of laser cutting machines for tube and pipe. Designed for high-performance processing of tube, structural and open geometries, the FT-250 streamlines non-cutting functions to maximize cutting uptime, according to company officials, who note that the machine redefines productivity by combining advanced machining capabilities, enhanced material handling and ease of operation.
Standard machine features: 6-kW power configuration and cutting head with focus detection. The programmable B axis enables bevel cutting of the material thickness for improved welding, multitube assembly, fit and finish. A proprietary U axis reportedly facilitates speed and productivity in a range of applications. The machine’s intelligent functions—Auto Profiler Calibration, Auto Nozzle Cleaning and Auto Focus Positioning—support machining productivity. The FT-250 is equipped with a high-speed precision centering system to minimize workpiece setup time and ensure accurate workpiece alignment. Enhanced support equipment provides material stability to secure workpieces during cutting and improve precision. Dual motion units designated for high-speed cutting and milling functions boost processing efficiency. And, the new machine design allows for quick access to processing areas and chucks for streamlined maintenance.
The user-friendly SmoothTube control interface features a dual panel with 21.5-in. touchscreen displays to provide operators with comprehensive views of the complete production process for intuitive control and easy operation. Operators can set conditions for scheduled operations and reprocess selected parts directly from the control without needing to edit the original program. And, Mazak’s Tube DX CAD/CAM software reduces human error with visual verification prior to production. High-precision simulations test processes from loading to processing and unloading for uninterrupted production.
See also: Mazak Optonics Corporation
Technologies: Cutting
There are no comments posted.Laserdyne Appoints Fabrizio Anzalone Chief Executive Officer
Monday, January 12, 2026
Compact 3D Laser Cutting Machine Tailored for Job Shops
Wednesday, November 19, 2025
BendingVehicle-Systems Manufacturer Pratt Miller Investing in Fabri...
Friday, November 7, 2025
