Mobile Pneumatic Tapping Arm
August 1, 2018Comments
FlexArm, Inc. has introduced the FlexArm mobile tapping package, which allows operators to tap holes offline as a secondary operation while primary production lines work on other parts.
The comprehensive package includes the FlexArm GH-18-1 tapping arm with a tap capacity of #6 to 5⁄8 in., reach from 17 to 72 in., variable speed from 100 to 420 rpm, 360-deg. movement and a semi-automatic tap lubricator. Additionally, with a caster cart, power pack, tap stand and five tap holders, this hydraulic tool can be used wherever a 110-V electrical supply is available—no air needed. The setup offers rapid set-up times and significantly reduced tap breakage, making the FlexArm an ideal alternative to tapping holes manually or via CNC.
With a tap breakage rate of 1/3000 holes, compared to 1/300 holes on a CNC, FlexArm tapping arms can significantly reduce setup time, cost and scrap rates, according to company officials.
FlexArm, Inc.: www.flexarminc.com
See also: Flexarm Inc., Division of Midwest Specialties
Technologies: CNC Punching
There are no comments posted.Murata Machinery USA Celebrates 50 Years of Automation in No...
Friday, February 23, 2024
Multifunction Fiber Laser Turret Punch Press
Tuesday, June 20, 2023
CNC Punching: Positive Stop a Positive Advantage
Lou Kren Monday, February 27, 2023
