Miro Manufacturing Adds Fabrication and Assembly Center
January 1, 2018
Miro Manufacturing, Inc., Waukesha, WI, has acquired property and a facility located less than a mile from its main campus to serve as the company’s fabrication and assembly center. The addition provides the company with more than 60,000 sq. ft. of manufacturing space. The company provides fabrication services that include laser and waterjet cutting, forming and welding, and assembly services that range from simple two-part sub-assemblies to complete product assembly. It also announced the addition of a Komatsu 330-ton servo press with a 36-in. coil-feed line. Miro’s presses range from 60 to 1000 tons.
Industry-Related Terms: Center, Forming, LASER
See also: Miro Manufacturing Inc.
Technologies: Coil and Sheet Handling, Fabrication, Stamping Presses
