Variable-Frequency Drive Dresses Up Hydroforming Presses
January 1, 2015Comments
Beckwood Press Co., St. Louis, MO, announced that its Triform line of sheet-hydroforming presses now will feature variable-speed drives as standard equipment on these models: 16-5BD, 24-5BD, 1648-5BD and 2448-5BD. Forming area on the presses ranges from 16-in. dia. to 16 by 48 in.; chamber pressure is 5000 psi standard, 10,000 psi optional.
The VFDs enable frequency and voltage supplied to the motors to vary based on press load, optimizing energy efficiency and reducing noise and heat generation.
Beckwood Press: www.beckwoodpress.com
There are no comments posted. Stamping Presses
Brad Kuvin Friday, March 29, 2024
Deep-Draw Sheet Hydroforming
Monday, October 23, 2023 Video
During FABTECH 2023, MetalForming Magazine Catches ...
