Key Considerations for Matching Components
In situations where companies or welding operators want or need to match off-the-shelf components rather than buying a complete welding system, there are a few tips to keep in mind. First, it’s always a good idea to consult a trusted distributor or equipment manufacturer when making the equipment selections.
It’s also important to consider the various types of wire feeders available and choose one that’s most appropriate for the application at hand, or for future applications. For example, if the job calls for eight hours of welding day after day, an industrial-type wire feeder is most appropriate. These feeders typically have more powerful motors, can run larger wire types and have more features than will a less costly and smaller wire feeder. While it’s important to note that these larger and more robust feeders may cost more upfront, they will generally pay for themselves over the long term.
Along with the right feeder requirements, other key considerations include amperage and duty-cycle capabilities. Be sure that the power source and welding gun provide the required duty cycle and amperage for the job, and that they are compatible in terms of their amperage capacity. Portability of the wire feeder also might be an important consideration, depending on the application.
Next, it’s important to match the interconnecting cables to ensure they are compatible with the available features of the wire feeder and power source. Some systems are digital, others analog; be sure to match the interconnecting cable to the appropriate system type. This may require assistance from the equipment manufacturer or distributor during the equipment-selection process.
Investing in a welding system may be a more expensive choice up front, but in many cases it can end up costing less in the long term, by eliminating downtime, improving quality and preventing lost productivity. Equipment manufacturers research and design welding systems to work together to enhance equipment features, increase productivity and ensure ease of use. For questions about the potential benefits of welding systems, or for help with selecting the right system for a given application, consult with a trusted welding distributor or equipment manufacturer. MF
Industry-Related Terms: Mesh, Run
