Gear Couplings for a Host of Fabrication Applications
October 1, 2014Comments
Desch Canada
Booth B1413
Desch gear couplings are flexible-shaft connections suitable for a positive-torque transmission. They’re designed to compensate for radial, axial and angular shaft misalignments. The gear couplings are made of steel with grease lubrication and O-ring seals.
Desch gear couplings are used in all areas of mechanical engineering and offer a long service life with maximum reliability, resulting from the optimal grease lubrication of the crowned spline. The couplings are generally suitable for horizontal assembly; special types are suitable for vertical assembly. Use them for shaft diameters from 20 to 1000 mm. www.desch.de/en
See also: DESCH Canada Ltd.
Technologies: CNC Punching, Coil and Sheet Handling
There are no comments posted.Murata Machinery USA Celebrates 50 Years of Automation in No...
Friday, February 23, 2024
Multifunction Fiber Laser Turret Punch Press
Tuesday, June 20, 2023
CNC Punching: Positive Stop a Positive Advantage
Lou Kren Monday, February 27, 2023
