Cosma Coil Lines Marry Coe Equipment and Siemens Controls
March 1, 2013Comments
Coe Press Equipment, Sterling Heights, MI, has installed three fully automatic coil lines at the new Magna Cosma facility in San Luis Potosi, Mexico. The lines are equipped with Siemens controls and software to enable programmability of all functions, including coil centering, edge-guide width, passline height, air-pressure settings, straightener-roll depth settings and all operating parameters. Two of the lines handle coils to 72 in. wide and 60,000 lb.; one feeds a WIA 800-ton progressive-die press, the other an Aida 1000-ton transfer press. The third line can process coils to 48 in. wide by 50,000 lb., and feeds a WIA 400-ton progressive-die press.
See also: Coe Press Equipment Corporation, Siemens Industry, Inc.
