Tube-End-Forming Machines
Tuesday, October 1, 2013
Manchester Tool & Die, Inc.
Booth S4045
Manchester Tool & Die, North Manchester, IN, will display its M71 tube-end-forming machines, equipped with the new servo flag stop positioning system— designed to aid setup personnel in quickly adjusting tube out through the machine’s HMI. This system will provide consistent adjustments resulting in quicker setup times.
Manchester Tool & Die supplies tube-end-forming equipment and tooling to a variety of industries, with machine capacity ranging from 3⁄16- to 3-in. OD.
See also: Manchester Tool & Die Inc
Posted by: aayushh on 4/29/2014 3:39:54 AM
because it will be cheaper in cost rather than hydraulic arrangement, even if hydraulic will be easier but for 2 or 3 post with 1500mm stroke of hydraulic cylinder will much costly for me. so kindly give me idea for same.Thanks.
