Modular Welding Table Maximizes Table Area and Load Capacity
October 1, 2013Comments
Strong Hand Tools
Booth N2249
Strong Hand Tools, Pico Rivera, CA, manufacturer of welding clamps, magnets, pliers and welding tables, will introduce its BuildPro Max modular welding table. This newest version of the BuildPro table provides a continuous tabletop surface of precision-ground steel plates (standard BuildPro tables include 1.7-in. slots between plates for use as clamping edges).
The 8- by 4-ft. BuildPro Max is constructed of precision, hardened steel plates with 5⁄8-in. machined holes in a 2- by 2-in. grid. Fabricators can insert clamps and modular fixturing components into the holes for unlimited options when setting up welding fixtures—dedicated, short run or prototypes. Each plate can be removed and reconfigured to extend the table width, and additional BuildPro plates can be added at either end or the sides.BuildPro Max table load capacity: 7500 lb. Order the tables with a standard finish, or with a nitrided finish for spatter- and wear-resistant corrosion protection.
See also: Strong Hand Tools
