Modular, Fine-Spray Lube System
Tuesday, October 1, 2013
Nordson EFD
Booth S4786
Nordson EFD, E. Providence, RI, displays its MC800 system, which applies lubricant in a fine, consistently even film. Its easy plug-and-play setup allows for on-the-fly adjustments in a variety of applications. With as many as eight individually controlled valves, the MC800 MicroCoat system offers a unique modular setup that allows the user to configure the machine to cater to the specific application needs. Low-maintenance operation and precise lubrication control decrease waste throughout the stamping process.
See also: Nordson EFD, LLC
Related Enterprise Zones: Lubrication
