Materials & Coatings
Protective Packaging for Steel Fabricators
Saturday, December 1, 2012
Dura-Fibre, Menasha, WI, introduces durable, puncture-proof laminated fiberboard that proves ideal for packaging fabricated steel products, as well as metal coils. The packaging board is manufactured with a blend of fibers that result in a strong base product. Multiple pieces of fiberboard are laminated together to create a finished product designed to resist tears, punctures and other abrasions. The product is lightweight and easy to handle, and slightly pliable to bend with the shape of the packaged products.
The packaging can be customized by size, and die-cut to fit the customers’ needs.
Dura-Fibre: 888/997-6543;
See also: Dura-Fibre Llc
