New Products
New Line of Servo Presses
Sunday, May 1, 2011
Stamtec, Inc., Manchester, TN, introduces its new CF1 series of servo presses, replacing the standard electric motor, flywheel and clutch/brake with a high-torque, low-RPM servo motor. Proprietary press controls designed specifically for the servo presses achieve a variety of stroke-length and slide-movement profiles, while supplying full working-energy capacity even at low speeds. This allows the user to perform a variety of jobs in one press, such as drawing, restrike and warm forming, and easily adapt to automation and feed applications. In addition, user-defined motion curves allow as many as 20 various segments in a cycle curve, defined by slide position, speed, and pause duration parameters.
Stamtec: 931/393-5050;
See also: Stamtec, Inc.
