Electrolux Cuts its Teeth on Stamping Stainless Steel
By: Brad Kuvin
Sunday, May 1, 2011
Stamped stainless-steel doors and drawers for electric and gas ranges once represented the most expensive parts outsourced by the Electrolux manufacturing facility in Springfield, TN. So says the plant’s purchasing engineer, Brenda Carr. Early in 2008, Carr decided to take a closer look at the process. Her hope was that the plant’s production team could run the jobs inhouse and enable tighter control of quality and costs. For starters, its supplier was experiencing an extremely high and costly reject rate.
  Starring at the new Electrolux stainless-steel press shop are two new presses—600-ton (above) and 400-ton (left) capacity, 144 by 60-in bed. Two associates on each side of the press perform a carefully choreographed routine to manually transfer blanks through the die sets at 300 strokes/hr.
“Rejects, due primarily to scratches and intolerable burrs on the stainless-steel stampings, averaged 12 to 15 percent,” Carr says. “We had only allowed for a scrap rate of 5 percent when we awarded the contract. So, we pulled together a team inhouse and examined all of the factors that would contribute to the PPV—purchased-part price variant. While we had some naysayers due to the complexity of stamping stainless steel, which we’d never done here before, we felt we could justify the investment needed to bring the work into our facility.”
That Pesky Protective Film
Stamping the stainless-steel range doors and drawers is a simple process of blank and form. However, the protective film covering each blank creates some challenges.
“When you shear that film down, getting the parts in and out of the die and keeping the die clean can be a challenge,” says Michael Sprouse, process owner in the plant’s new stainless-steel stamping area. “Also, secondary deburring operations required on the parts create opportunities to mar the surface finish of the parts. We had to elevate both processes—die cleaning and deburring—compared to what our supplier had been doing, in order to sufficiently improve quality and reject rate, and reduce deburring costs. That’s how we ultimately were able to justify adding press capacity to handle the job.”
The job: Inherit 23 transfer dies from its supplier to manufacture 30 stamped parts, of 22-gauge Type 201 and 430 stainless. Blank size: 30 by 20 in. Each part requires hits in three or four dies. The plant’s supplier only had presses sized to hold two dies at once, so each part required setup and processing in two presses. This caused a substantial amount of in-process inventory, and added material handling—opportunities to mar the surface finish. Sprouse and the rest of his production team, including fabrication manager Frank Byrne and senior maintenance engineer Mark Frauendienst, specified new presses for their plant that could accommodate as many as four dies, to stamp completed parts in one cycle.
“Bed size was more important than tonnage when we went shopping for presses,” says Byrne. “And although volumes allowed us to initially perform the work with manual transfer of blanks, we wanted the ability to set up the new presses with feed lines down the road, should volumes grow to a certain point. We also sought flexibility to allow us to run other coil-fed work on the presses.”
5S, OEE Help Clear Floor Space
Inspectors take a close look at every stainless-steel part exiting the plant’s two new stamping presses, on the lookout for burrs, blemishes and scratches. Left: A Type 201 stainless-steel door panel; below: a Type 5430 drawer panel. Since bringing the work inhouse, scrap costs have been cut in half, to a mere 3 cents/unit
manufactured.
An 80-by-40-ft. area once used to house inventory now is the home of the firm’s new two-press stainless-steel press shop. Byrne credits the plant’s effective application of the Electrolux Manufacturing System (EMS) with its ability to slash the amount of inventory it keeps on hand, thanks to dramatic improvement in overall equipment effectiveness (OEE).
“We run a very tight ship here,” he says, noting how hard-pressed the facility is for space. “If you’re looking for evidence that paying attention to OEE, 5S and minimizing inventory pays off, this is it. We gained the floorspace we needed to bring in two new presses, complete with walks and aisle space for lift trucks, to realize Brenda’s vision of bringing the stainless-steel work inhouse, saving the company a lot of money.”
Sweden-based AB Electrolux launched its global manufacturing system (EMS) in 2005 to improve safety, quality, cost and delivery. Nearly all of its plants have adopted the system, which addresses three fundamental strategies:
• Stability—defined as standardizing methodologies throughout the company to eliminate waste.
• Process improvement—continuously improving working methods to upgrade quality, cost and delivery performance.
• Culture change—focusing on building leadership skills and teamwork, and investing in training for every member of the company’s team.
 Closer Look at
Press Technology
 Electrolux’s two new Stamtec presses feature fabricated box-frame construction and four full-length steel tie rods prestressed to 150 percent of press capacity. Eight full-length 90-deg. gibs, with nickel-bronze wear plates, guide the slide. Each press also boasts a high-torque low-inertia clutch and separately mounted air-released spring-actuated brake, automatically synchronized. Dual-valve automatic hydraulic-overload protection systems protect each side of each press individually from overloads. Also, each press includes a set of four die safety blocks interlocked to the press controls to prevent inadvertent operation while the safety blocks are in use.
Press specifications: 14-in. stroke; 20- to 40-strokes/min.; 144- by 60-in. bolster and slide area; parallelism (slide to bolster) of 0.001 in./ft. or less; deflection of 0.0015 in./ft. or less right to left and front to back, with two-thirds of the bed area symmetrically loaded.
Omnilink 5000 press and automation controls on the presses, from Link Systems, provide the plant the opportunity to eventually evolve from manually fed operations to automatically fed. The units offer clutch-brake control, auxiliary-systems control, die protection and process monitoring, signature and tonnage monitoring (which Electrolux hopes to eventually use to gauge burr height and trigger die maintenance), and automated setup of counterbalance, die cushions and shut height.
Now Electrolux has begun to spread the love, by conducting EMS workshops for its suppliers. A big part of implementing EMS and gauging its success is the constant measuring of key performance indicators (KPIs)—at each plant and company-wide. The EMS reaches throughout each factory, with KPIs established at varying levels specifically for use in either a production office or out on the shop floor. Typical KPIs include overall equipment effectiveness (OEE) and job-change-over time including die-change times.
At the Springfield facility, improving OEE and changeover efficiency delivers numerous benefits, the primary benefit being expanded press capacity. Its average press-line OEE is 70 to 75 percent, an improvement of 10 to 15 percent since implementing the EMS. And, die-change times on some presses have been reduced by as much as 40 percent.
Back to the Stainless-Steel Press Shop
Starring at the new Electrolux stainless-steel press shop are two new Stamtec presses—600- and 400-ton capacity, 144 by 60-in bed. They run the stainless-steel parts five days/week, two shifts/day. A team of five works at each press—four press operators who manually transfer blanks through the die sets, at 300 strokes/hr., and a material handler/inspector.
“We now have press capacity that we didn’t have before,” says Frauendienst. “So, we’ll be looking to add feed lines to the presses within the next year or so to increase flexibility.” Also possible down the road, as stainless-steel appliances continue to gain traction in the marketplace and volumes pick up: transfer automation. In just the last few years, the company’s orders for stainless-steel appliances have nearly tripled.
“We may soon have to look at adding transfer systems to these two presses,” says Frauendienst. “There’s plenty of space on the presses for mounting a transfer system, and the controls (OmniLink 5000 models from Link Systems) make the presses automation-ready.”
Results from the overall project have been impressive. First, the plant gained control of the process. Says Sprouse: “Schedule changes are easily accommodated. Also, scrap and rework rates are down considerably—scrap is a mere 3 cents/unit manufactured, half what it was previously, thanks to the dedication of our crews to keep the dies clean. Reject rate from the press is less than one percent, and through the entire system (including deburring, coating etc.) scrap rate is less than two percent.”
Less Deburring Contributes to Lightning-Quick ROI
Another benefit realized from gaining process control inhouse: Only about half of the parts actually require deburring, whereas all stampings were undergoing the secondary process previously. What no longer needs deburring? Those stampings that undergo a special Electrolux-developed anti-fingerprint stainless-steel coating process, thick enough to cover any burrs typically produced.
“We used to pay for deburring of every part stamped by our supplier,” says Carr, noting that acceptable burrs off the press are 0.004 in. or smaller. Larger burrs create problems for the company’s subcontracted deburring house. “Not only are we saving time and money thanks to less deburring, but we eliminate one more opportunity to have the surface finish of the parts marred,” Carr adds.
When accounting for all of the benefits, the stainless-steel stamping project allowed Carr to realize a substantial improvement in PPV and overcome a company-wide freeze on capital spending. “Our case was simply too good,” she says. Using a modest run rate of 50 units/hr. (compared to the actual run rate of 300/hr.), Carr and the plant’s production team were able to show a 9-month return on investment for the project.
“The presses are performing, the dies are performing, and the people are performing,” says Frauendienst. MF
See also: Link Systems, Stamtec, Inc.
Related Enterprise Zones: Presses, Quality Control, Sensing/Electronics
Posted by: Hershel on 2/21/2018 11:08:48 PM - URL: http://game7vienngocrong.net/forum/profile.php?id=1061
Greetings! Very useful advice within this article! It's the little changes that make the most significant changes. Thanks for sharing!
Posted by: Jason on 2/17/2018 1:25:07 PM - URL: https://medium.com/@socialbuzzfr13
Elle fait état de 1,5 milliard de vidéos vues. https://medium.com/@socialbuzzfr13
Posted by: Augustina on 2/14/2017 5:06:40 AM - URL: http://bit.ly/2kYLbhg
Wow, this article is good, my sister is analyzing such things, therefore I am going to tell her.
Posted by: Carla on 12/29/2016 10:11:24 AM - URL: http://www.ministryofcannabisblog.com/fr/2015/03/spannabis-2015/
MAIS AUSSI ENSUITE ME DONNER CES INDICATIONS EXACTE A FAIRE. ( Genre: quand aroser, quand exposer an une lumiere... ) Merci d'avance.
Posted by: Joleen on 12/23/2016 7:58:22 AM - URL: http://ow.ly/oExk306djPs
Hi, I want to subscribe for this website to get latest updates, therefore where can i do it please assist.
Posted by: Myrna on 8/23/2016 8:15:06 PM - URL: http://emed.pp.ua/index.php/component/k2/itemlist/user/10720
Hello, I do believe your online site may be having internet browser compatibility issues. Whenever I review your website in Safari, it looks fine however, if opening in IE, it's got some overlapping issues. I simply wished to provide a quick heads up! Aside from that, wonderful website!
Posted by: Louvenia on 8/5/2016 6:57:41 PM - URL: http://www.wrap-box.net
I do not know if it's just me or if everyone else experiencing issues with your site. It looks like some of the written text in your content are running off the screen. Can someone else please provide feedback and let me know if this is happening to them too? This might be a problem with my internet browser because I've had this happen previously. Kudos
Posted by: Orlando on 6/16/2016 10:55:24 AM - URL: http://galleriachirulli.com/?option=com_k2&view=itemlist&task=user&id=609883
Hmm it seems such as your site ate my first comment (it had been extremely long) and so i guess I'll just sum it up the things i wrote and say, I'm thoroughly enjoying your blog. I too am an aspiring blog writer but I'm still a novice to everything. Do you have any points for inexperienced blog writers? I'd certainly appreciate it.
Posted by: Carolyn on 3/6/2016 2:45:51 AM - URL: http://xusicapi.wix.com/buy-instagram-likes#!how-to-get-followers-on-instagram/n37ia/56cb1f4c0cf2836ff5d4f204
Excellent, what a webpage it is! This website gives valuable data to us, keep it up.
Posted by: Michale on 1/19/2016 2:04:24 PM - URL: http://www.banatkamla.net/component/k2/author/437056.html
Her får du en præcis angivelse af hvilken internet hastighed du har i dag og falder den under deet behov, bør du kigge efter en hurtigere forbindelse.
Posted by: Fae on 1/17/2016 2:31:19 PM - URL: http://www.Dreistes-gaming.de/index.php?mod=users&action=view&id=29358
What are these shoes meant to do to aid your vertical leap. The best way to build up it's by actually doing it. No resting or taking a little step prior to next jump.
Posted by: Cesar on 1/15/2016 8:35:58 AM - URL: http://Americanpave.com/component/k2/author/660764
Acabou por transformar este problema, comum entre muitos empreendedores, num negócio.
Posted by: Gertrude on 1/13/2016 12:44:07 PM - URL: http://knu.cmelak.cz/index.php?option=com_k2&view=itemlist&task=user&id=693806
Wonderful article! This is the kind of information that are supposed to be shared around the internet. Disgrace on the search engines for now not positioning this post upper! Come on over and talk over with my website . Thank you =)
Posted by: Genie on 12/16/2015 2:07:33 AM - URL: http://www.fachschaftsrat.info/index.php?page=User&userID=837340
Its like you read my mind! You appear to know a lot about this, like you wrote the book in it or something. I think that you can do with a few pics to drive the message home a little bit, but other than that, this is great blog. An excellent read. I'll certainly be back.
Posted by: Donnell on 12/16/2015 12:19:17 AM - URL: http://www.welov3.com/en/7-sensations-most-people-dont-know-about-instagram/
You actually make it seem really easy with your presentation however I to find this matter to be really something that I believe I'd never understand. It sort of feels too complicated and very extensive for me. I'm taking a look ahead to your next put up, I'll attempt to get the dangle of it!
Posted by: Margherita on 12/15/2015 7:08:27 PM - URL: http://Www.mariadolorespaoli.com/component/k2/itemlist/user/157784.html
I have rewad so many posts concerning the blogger lovers bbut this paragraph is really a fastidious piece of writing, keep it up.
Posted by: Paul on 1/5/2012 12:07:45 PM
I am having a lot of issues with my stamped stainless steel parts being rejected due to "Bumbs" caused by either particules from the initial stamping or the film from the parts. Looking for a solution to keep the parts and die clean before stamping.
YOUR NAME *
EMAIL *
WEBSITE
