A Look Ahead
The trend a from HSLA steels to AHSS (Fig. 4) is noteworthy. Use of AHSS in North American light vehicles is expected to grow from 9.5 percent in 2007 to an estimated 34.8 percent in 2015.
The search continues for AHSS grades with even better properties. So far, our discussion covers Generation 1 AHSS grades (Fig. 5). A major jump in forming capability comes via the austenite-based products of Generation 2, such as TWIP (twinning induced plasticity) steels that are just now beginning preproduction experimentation. While these steels claim 60-percent total elongation and very high n-values, they are costly due to the high cost of alloying elements. Also, their complex composition makes the alloys challenging to weld.
Many researchers believe that most parts do not require the mechanical properties of Generation 2 AHSS grades, and so have begun to develop Generation 3 steels. These grades will feature less complex compositions than Gen 2 steels, and exhibit improved formability and weldability.
Special Areas of Concern
Even with the expected infiltration of AHSS grades in vehicles and other products, concerns remain. Among them: springback; forming speed and heat buildup in the die; and press tonnage and energy.
Springback als is present when forming lower-strength steels, and requires die compensation to meet part prints. The amount of springback relates directly to yield strength. So it follows that AHSS, particularly CP and MS grades, prove especially difficult to control because of the large amounts of springback (Fig. 6). While common low-strength AKDQ steel typically exhibits springback of 2 to 3 percent, and springback of an HSLA steel typically is 8 to 12 percent, an MS steel exhibits springback of 16 to 24 percent.
Springback, sidewall curl, and panel twist all have their origins in unbalanced stresses in the formed part. These stresses often result from the product design—nonsymmetrical geometries or cutouts, rapid changes in cross section or unequal flange lengths. Other causes include inconsistent forming-process parameters, including lubrication, polishing, blankholder forces, blank positioning and broken or worn draw beads.
Because springback is such a major concern in AHSS applications, it must be addressed early in the design phase to avoid post-forming springback compensation. To minimize springback in the design phase:
• Avoid right or acute angles.
• Use large open-wall angles to allow overbending and springback—6 to 10 deg. is preferred.
• Avoid large transition radii between two walls.
• Use open-end rather than closed-end stampings.
• Use stiffeners, darts, step flanges, etc. to prevent the release of elastic stresses and reduce springback, where part design allows.
• Design punch radii as sharp as formability and product design will allow. Radii less than 2t will reduce springback angle and variation.
Because steel work-hardens as it is drawn over a die radius, the resulting higher strength will cause increased springback and sidewall curl. This makes restrike operations difficult. Thus, stampers should strive to limit material movement across these radii.
Automotive design engineers often specify the use of channel or hat-style sections in structural product designs. Unfortunately, the 90-deg. angles, parallel walls and the need to bend the sidewalls over a radius all contribute to the potential for increased springback. To achieve a desired channel height while limiting movement across radii, form hat sections using a two-step approach—the gull-wing process (Fig. 7). First, form all 90-deg. radii and mating surfaces with the required overbending for springback compensation. Flattening the large radius in top of the hat section occurs in the second operation, which may require additional overbending of the flat, top section to produce parallel walls.
Multistep forming operations prove helpful for parts having small, severe geometry features that can only be formed in restrike stations. Another such method is called Shapeset, a form-and-flange die process developed at General Motors Research (Fig. 8). A form die or draw tool (without draw beads) forms the part, which is then placed into a second tool designed to lock out the remaining flange. A lower pressure pad with lock beads engages the blank and upper die steels approximately 6 mm or less from bottom-dead center (BDC). The part is then stretched over a die post prior to the press reaching BDC.
The resulting stretch (about 2 percent) in the part usually will sufficiently reduce residual stresses and part-to-part variations. A lower lockdown device is required to avoid deforming the part on the upstroke caused by opposing pressure pads.
Forming with wiping dies requires the use of pressure pads to prevent the workpiece material from slipping when formed. Pad-pressure requirements for wiping dies generally equal the punch force required for forming—for AHSS, pressure-pad force may be three times that required for an equivalent thickness of HSLA. These levels of holding force may be difficult to achieve in small wiping dies or in a small die area.
More Tooling Techniques to Control Springback
The higher forming stresses on die materials and the need to further work the material to reduce springback can potentially create large tool deflections. Forming steels must be keyed and properly heeled to control tooling deflection and maintain part quality.
Stampers should incorporate overbending into the wiping die to compensate for springback. Anticipate as much as 10 deg. of springback, depending on the grade.
Fig. 9 illustrates a springback-compensation technique found in the High Strength Steel Stamping Design Manual, published by the Auto/Steel Partnership. The flange steel has a radius less than the part radius, coupled with back relief on the flange steel and forming post. Back relief on the flange steel allows application of additional pressure further out on the formed radius.
To coin AHSS and reduce the material thickness through the radius, the die must exert very high pressures in the flange-steel corner radius. Significant concerns under these conditions include flange-steel wear, strength and reliability.
Where practical, consider use of rotary forming tools in place of flange wipe dies. Rotary forming tools prove easier to adjust for springback compensation, and the tensile loading (additional stretch increment) generated by wiping tools.
Forming Speed, Energy, Heat and Lubrication
The increase in yield and tensile stress of AHSS with forming speed is minimal–only 2 to 3 ksi/per 10-fold increase in forming speed, from tensile-test speed to 10 in./in./sec. (many press forming speeds). This stress increase is less than that for AKDQ steels. Over the same forming speeds, the work-hardening exponent remains constant.
While the increase in strength for a press-speed increase from 12 to 16 strokes/min. is negligible, the number of parts, amount of energy and the accompanying heat increases by 33 percent. When changing strength levels (grades) within a steel type, higher-strength grades also require greater force, resulting in additional energy and heat. This increase in heat can reduce lubricant viscosity and even cause lubricant breakdown.
Press Tonnage and Energy
An obvious concern when stamping AHSS is the force capacity of the stamping press. Less obvious, but of primary concern, is the available press energy to carry out the stamping operation and keep the press running continuously. Press tonnage and press energy are not the same.
The tonnage rating of a press represents the largest load that the press can apply without causing structural damage to its frame, slide-adjusting mechanisms, connection rods or main gear bushings. Calculate the tonnage required to carry out the necessary work (W) by multiplying applied force (f) and its working distance (d): W = f x d.
The energy rating of a press depends on the applied press load and the distance through which the load is applied. Consider deep drawing an HSLA steel, pushing 200 tons through 3 in. This application requires 600 in.-tons of energy. Forming AHSS could require 500 tons of force working through the same 3 in., expending 1500 in.-tons of energy.
Because energy is expended with each stroke of the press, and this energy must be replaced, critical attention must focus on the size of the main drive motor (horsepower) and the rotational speed of the flywheel, especially for AHSS applications. The amount of energy stored in the flywheel depends on its mass and rotational speed—stored energy varies by the square of the speed. Thus, a large amount of energy can be stored in the flywheel when the press runs at full speed; the available energy of a press diminishes as its speed drops. This is important to realize, because many stampers will reduce the operating speed of a press to reduce the amount of additional heat generated when forming AHSS. However, at these slower speeds, flywheel size becomes the limiting factor for delivering the required press energy. We recommend use of computer-based forming simulations to evaluate force and energy requirements when stamping AHSS.
Lastly, consider the attributes of a servo-drive press when determining press force and energy requirements—that’s the subject of this month’s Tooling By Design column. MF
Technologies: Materials
