Tooling Update
Metric Two-Post Direct Lifters
Wednesday, July 1, 2009
Dadco, Plymouth, MI, has introduced
Metric two-post direct lifters
two-post direct lifters as part of its line of metric air cylinders. TDL2 and TDL4 lifters feature the company’s HP series of metric air cylinders that include adjustable cushion control, built-in lubrication system and position-sensing capability. The new lifters feature linear bearings to deliver smooth, consistent lifting action in a variety of applications, according to company officials.
The TDL2 is offered in bore sizes in diameters from 40 to 100 mm and in stroke lengths from 25 to 400 mm. The TDL4 is equipped with a 40-mm-dia.-bore air cylinder available in stroke lengths from 25 to 250 mm.
Dadco: 800/323-2687;
See also: DADCO, Inc.
