Hill Engineering Restructures, Moves
Wednesday, July 1, 2009
Hill Engineering, Carol Stream, IL, a Formtek company, sold off its gasket tooling division and moved to new facilities. The firm manufactures equipment for rollforming and tube manufacturing, including flying cutoff and punching dies, inline flying saws, pneumatic and hydraulic presses and rotary punching machines.
See also: Hill Engineering, Inc., Formtek Group, Inc.
Posted by: Mike Jusick on 9/16/2015 8:46:20 AM
We have an application where we need to cut condut. The conduit o.d. is 9.0 +0.05 -0.15 mm AND THE i.d. is 3.5 mm. Our production line speed is 15 meters per minute and te cut lengths range between 500 mm to 3000 mm. The cut tolerance is +/- 1 mm. The cut edge should be perpendicular to the axial centerline +/- 3 degrees, and free of burrs. We would like a minimum of 5000 cuts before changing the blade. If you can give me a rough estimate of the cost for such a saw it would be appreciated. Mike Jusick Product Development Manager Kongsberg Automotive - Driveline division Novi Michigan
