Gas-Spring Four Pack Ideal for High Force in Small Spaces
December 1, 2009
Gas-spring four pack
Dadco introduces its SCR series of nitrogen gas springs, in four models designed to deliver powerful force in a small package. A port at the bottom of the spring facilitates pressure adjustment, charging or linked operation using Dadco’s MiniLink fitting system. Diameter ranges from 32 to 63 mm, stroke length from 10 to 80 mm, and force rating from 0.5 to 3.2 tons on contact.
Dadco: 734/207-1100; www.dadco.net
Industry-Related Terms: Stroke
See also: DADCO, Inc.
Technologies: Tooling
