Bend Tooling Upgraded
August 1, 2008Comments
Anchor Danly offers a datasheet
Using a simple design, the Accu-Bend transfers the vertical motion of the press into a smooth one-motion rotation. The smooth rotation provides a rotary-bend process that uses less tonnage and applies less strain on the material, according to company officials.
Accu-Bend tools include a tool-steel rocker in a steel saddle with a graphite-plugged aluminum-bronze liner. The units hold bend-angle tolerances of ±0.5 deg., and can overbend by as much as 120 deg. Use the tool to make these and other bends: square and over- or under-square, Z, channel, hat and J.
Anchor Danly Co.: 248/489-7816; www.anchordanly.com
See also: DAYTON Lamina Corporation
Technologies: Tooling
There are no comments posted. Tooling
Brad Kuvin Monday, February 27, 2023
New Die Steel Reduces Wear on Form Details
