New Products
Waterjet-Cutting System--Ideal for Steel Service Centers
Tuesday, July 1, 2008
Waterjet-cutting system-Ideal for steel service centers
Bystronic Inc., Hauppauge, NY, introduces the Byjet L abrasive waterjet-cutting system optimized for the processing of large sheet sizes. The machine is ideal for steel service centers and other companies that need to process large volumes of waterjet parts or large sheets. The base frame of the machine is a modular construction that can be expanded in 6.5-ft. increments. Models offered range from Byjet L 2030 with a 6.5 by 10-ft. cutting area, to the Byjet L 16030 with a 52.5 by 10-ft. cutting area. All models include two cutting heads with automatic head spacing, height sensing and collision protection. Optional third and fourth cutting heads are available.
Bystronic Inc.: 631/231-1212;
See also: Bystronic Inc.
