New Products
Modular Spray-Lubrication System
Sunday, June 1, 2008
The Jet-Set MOD-1E unit from Michigan
Modular spray-lubrication system
Manufacturers Service Inc., Wixom, MI, is an electrically activated module package containing a solenoid that can be integrated into a machine’s control system to provide a desirable lubrication cycle to meet users’ needs. It is equipped with the No. 1401 Repeat Cycle Timer option, allowing the user to activate the pump any number of times within a given time period. The timer allows multiple shots of lubricant on the stock during several press cycles. The MOD-1E comes standard with a 9100 pump that will provide millions of cycles of maintenance-free operation. All Jet Set pumps provide simple volume regulation by just turning the large volume-control knob on top of the pump.
Michigan Manufacturers Service: 248/348-3900;
See also: Michigan Manufacturers Service
Related Enterprise Zones: Lubrication
