Tooling Update
High-Speed Handheld Tube Beveller
Sunday, June 1, 2008
A high-speed, handheld pneumatic beveller from Esco Tool, Medfield, MA, features an automatic pilot-locating system that eliminates setup time and performs end preps in only a few seconds.
The Millhog beveler includes a pilot that automatically seats in the tube ID, and a cutterhead with field-replaceable carbide blade inserts and multiple cutting edges to perform 37.5-deg. end preps. It can bevel a single tube in 3 sec. and can be supplied with an optional track-mount system for rapidly end-prepping full panel sections.
Providing torque-free operation without cutting oils, the Millhog is ideal for repetitive end preps. Straight-through and right-angle models operating at 5000 or 10,000 rpm are offered with working ranges from 0.45-in. ID to 4-in. OD.
Esco Tool: 508/359-4311;
See also: Esco Tool
