Safety Update
Safeguarding Workers During Welding and Cutting
Tuesday, April 1, 2008
Article provided on behalf of the American Industrial Hygiene Association ( by Michael Larrañaga, associate professor and department head, School of Fire Protection and Safety, Oklahoma State University, Stillwater, OK.
Welding, cutting and brazing pose health risks to more than 500,000 workers; the risk of fatal injuries is more than four deaths per thousand workers over a working lifetime.
safegarding workers during welding and cutting
Welders can be exposed to fire, ultraviolet and infrared radiation as well as intense visible light. Before allowing an operator to begin cutting or welding, fabricators should perform a fire-hazard inspection of the area, as designated in a written safety plan. They should either remove all combustibles; shield them from ignition sources; or employ appropriate guards to confine the heat, sparks and slag generated during cutting and welding. And, when welding outdoors in dry conditions, ensure that a trained fire watch with extinguishing equipment is present.
The consequences of welding and cutting without taking the appropriate safety measures can be extremely serious. The upper respiratory tract, nose, throat and eyes are at risk. Short-term exposures may lead to pulmonary edema, lung irritation, chemical pneumonia and other respiratory illnesses. Exposure to zinc fumes can cause metal-fume fever, the symptoms of which are very similar to the flu.
OSHA requires sampling during welding to determine if exposure levels fall within acceptable ranges. If not, the employer must take the necessary steps to bring exposures to acceptable levels.
PPE—Employees exposed to hazards created by welding, cutting or brazing operations must be protected by personal-protective equipment (PPE) in accordance with OSHA requirements. Appropriate protective clothing required for any welding operation will vary with the size, nature and location of the work to be performed. Burns from touching hot surfaces and not using PPE poses one of the most common welding-related risks, as does electrocution from high voltage and electrical current.
Welding PPE may include welding hoods, goggles, nonflammable shirts and pants, welding gloves and steel-toed boots. A respirator or positive pressure hood can minimize exposure to metal fumes produced during the welding process.
Chemical hazards—Als ensure—never assume—that the welding surface is free of chemicals, greases and other hazardous materials before welding begins. A number of potentially hazardous materials are used in fluxes, coatings, coverings and filler metals used in welding and cutting, or are released to the atmosphere during the process. Metals themselves, oxides of metals, and different types of chemical gases can be released during welding.
Confined spaces—All welding and cutting performed in confined spaces requires adequate ventilation to prevent the accumulation of toxic gasses, the possibility of fire or explosion and oxygen deficiency. This applies not only to the welder but also to helpers and potential rescuers. Companies should consult OSHA confined-space standards and general industry recommendations.
Training—Management must insist that cutting and welding operators and their supervisors receive training in PPE use and function; the ability to make decisions about when to use PPE; and the effective use of fire extinguishers and fire-prevention methods. Refresher safety training also should be required.
For more information and to access a list of industrial-hygiene consultants specializing in these issues, visit the American Industrial Hygiene Association at
See also: American Industrial Hygiene Assoc.
Related Enterprise Zones: Safety, Welding
