Nibbler Cuts Forward and Backward
Saturday, March 1, 2008
Trumpf, Farmington, CT, will exhibit its N700-2 nibbler, which can rotate the punch guide and allow the nibbler to cut in a backward direction. This allows the operator to pull the tool toward him, an excellent safety feature. The N700-2, reportedly the world’s smallest and lightest nibbler in the heavy-duty class, comes standard with two different handles that quickly can be exchanged; punch changes require no tools. Use the nibbler in a variety of applications including coil applications, sheetmetal fabrication and building maintenance.
See also: TRUMPF Inc.
