Die Design and Build Plus Machining
Saturday, March 1, 2008
Progressive Tool Co., Waterloo, IA, specializes in design and build of progressive, transfer and line dies and also provides other machining services. The company will feature its two-axis, servo-driven, die-mounted transfer system and will display an operating model. The company also will spotlight parts out of dies, along with parts produced from other departments within the company including wire-EDM details, waterjet-cut parts and stereo-lithography plastic prototype parts. Progressive Tool has CNC-machining capabilities for spare die details and custom and production machining requirements. The company has purchased a new CNC bridge mill with 71 by 126 in. of travel, which expands its large-machining capabilities.
See also: Progressive Tool Company
