Brazing Machine for Low-Volume Applications
March 1, 2008
Brazing machine for low-volume applications
Fusion Inc., Willoughby, OH, displays the Braze Mate, a machine for brazing and soldering in low-volume applications or short runs of various part styles. Available in two models, the Braze Mate offers automatic, timed heat control, with multiple torches attached to a retractable arm. Rates from 50 to 100 parts/hr. are typical.
The production sequence begins with an operator loading a part into a stainless-steel fixture. A deposit of Fusion paste alloy is applied to the joint area with a hand-held applicator. The operator then activates the heat cycle, automatically positioning the burners in the heat zone. Oscillating burners eliminate hot spots at the assembly joint area.
www.fusion-inc.com
Industry-Related Terms: Fixture
See also: Fusion, Inc.
