Light Curtain Helps Reduce Downtime
October 1, 2008
C4000 Select safety light curtain
Sick, Inc., Minneapolis, MN, has introduced the C4000 Select safety light curtain. It allows customers to use DIP switches for configuration rather than a PC and offers an integrated laser alignment tool. Features include condensed, intuitive diagnostics andthe ability to cascade three C4000 Select pairs or a S300/S3000 safety laser scanner.
C4000 Select - Sick, Inc.Use the C4000 Select for point-of-operation safeguarding applications as well as for perimeter and area-guarding applications.
Benefits include reduced installation cost and start-up time with quick DIP switch configuration, rapid alignment, increased mounting flexibility and condensed, simple-to-understand local diagnostics. Selectable features include safety field width, two beam codes, one- or two-beam floating blanking and extended I/O. An optional 360-deg. integrated LED status indicator provides highly visible output status from a distance.
Sick, Inc.: 952/829-4728; www.sickusa.com
Industry-Related Terms: Blanking, LASER
See also: SICK, Inc.
Technologies: Safety
