Plasma-Cutting Kits Combine Torch, Consumables
Sunday, June 1, 2014
plasma cutting kits combine torch, consumables American Torch Tip, Bradenton, FL, introduces its PHD 260X and 400X plasma-cutting kits, featuring 260- and 400-A component sets that include a quick-disconnect torch, consumables and more. Components (10 electrodes, 10 nozzles, two swirl rings, etc.) are compatible with HPR 260XS and 400XD apparatus. Use the equipment to cut mild and stainless steels and aluminum alloys to 45 mm thick.
American Torch Tip: 941/753-7557;
See also: American Torch Tip
