Clinch Studs Resist Torsional Load
December 1, 2013Comments
Rifast Systems LLC, Lincolnwood, IL, has launched a new line of clinch studs. Dubbed Torqex (Torque Extreme), the studs, when installed in sheetmetal 2.75 mm thick or greater, create a connection between the fastener and sheetmetal that cannot be broken by torsional loads.
The firm offers samples of M8 x 32-mm studs at grade 10.9 steel and A286 stainless steel. The studs have been successfully tested in 3-mm steel exhaust flanges, Grade 50 HSLA and 3.5-mm hot-rolled steel.
Order the studs as a complete package for in-die installation or as studs only for stand-alone secondary operations.
Rifast: 847/933-8341; www.rifastllc.com
See also: Rifast Systems LLC
Technologies: Tooling
There are no comments posted. Tooling
Thursday, March 7, 2024
All-Electric Clamps Designed to Reduce Emissions, Slash Ener...
Friday, January 26, 2024
Echo Industries Purchases Haas VF2 Vertical Milling Machine ...
Friday, December 1, 2023
PTM Corporation: Your Source for Tool Design and Build, Prot...
