Fiber Laser Cutting Systems
Sunday, July 1, 2012
Hypertherm, Inc., Hanover, NH, introduces two new HyIntensity Fiber Laser systems—the 2-kW HFL020 and the 1-kW HFL010. The new machines join the firm’s 1.5-kW model unveiled in 2010 as reportedly the first fully integrated fiber laser systems designed specifically for marking and fine-feature cutting.
The cutting machines offer optimum performance on a range of applications and deliver consistent cut quality across a host of material types, including brass and copper, as well as mild steel to 5⁄8 in. thick.
And, fabricators can easily integrate and install HyIntensity systems onto existing cutting tables, including those already running a plasma-cutting torch.
Hypertherm, Inc.: 603/643-3441;
See also: Hypertherm, Inc.
