Stand Mounts Ease Conveyor-Belt Changes
July 1, 2011
Dorner Mfg., Hartland, WI, introduces cantilever stand mounts to allow fabricators to easily open their conveyors for fast belt changes. Cantilever stands support the conveyor from only one side, which opens the other side up for easy access. This feature proves ideal when conveyors are placed it tight locations or for applications that require frequent belt changes.
Standard conveyor stands often must be removed to facilitate a belt change; cantilever stands allow the belt to slide off without removing stands, and by only one technician. The unique side-support design of the cantilever stand mount also provides easy access for employee interaction and more efficient cleaning, by eliminating obstructions to the conveyor. The cantilever stand mounts are engineered to work with Dorner’s 2200 and 3200 Series conveyors from 2 to 24 in. wide.
Dorner Mfg.: 800/397-8664; www.dornerconveyors.com
See also: Dorner Manufacturing Corporation
