Tooling Update
Future Products Adds Makino High-Speed Wire EDM
Sunday, May 1, 2011
Die-tooling and machined-components manufacturer Future Products, Clawson, MI, has added a Makino DUO43 CNC wire EDM to its stable of equipment. The machine boasts a 28- by 22-in. work table and 17.7-in. X axis, 11.8-in. Y axis and 12.6-in. Z axis. The machine features high wire-tension technology developed for optimum shape accuracy, says Makino literature, particularly in corner geometry. Positioning accuracy and repeatability are rated at ±0.00006 in. (full stroke) in 1.6-in.-thick tool-steel plate; roundness accuracy is ±0.0002 in. in 1.6-in. plate with a 0.8-in. hole diameter.
Read up on Makino’s DUO43 at
Future Products: 800/237-5754;
See also: Future Products Tool Corporation
Related Enterprise Zones: Other Processes
