Gas-Spring Wall Chart Matches Charge Fittings to Spring
September 1, 2010Comments
Hyson Products, Brecksville, OH, has issued an updated wall chart that matches quick disconnects/charge fittings to the appropriate gas spring. The 17- by 22-in. color chart shows each quick disconnect at its exact size, for simple ID and selection. The photos are matched with a list of the gas-spring models that use each fitting.
Hyson Products: 440/526-5900; www.hysonproducts.com
See also: HYSON
Technologies: Tooling
