New Products
Part-Revolution Controls
Thursday, April 1, 2010
Rockford Systems, Inc., Rockford, IL, introduces
SSC-1500 dual-microprocessor-based control system
the SSC-1500 dual-microprocessor-based control system and the SSC-3000 solid-state press-automation control system, both of which comply with OSHA regulations and ANSI safety standards.
The SSC-1500—with a large, user-friendly keypad/display—finds use on part-revolution-clutch power presses and press brakes. Redundant inputs from devices such as palm buttons, foot switches and light curtains provide control reliability.
The SSC-3000 control, also for use on part-revolution-clutch mechanical power presses, is a rack-mounted modular control with expandable options that allow a metalformer to add or delete features as requirements change.
Rockford Systems: 800/922-7533;
See also: Rockford Systems, LLC
Related Enterprise Zones: Automation, Sensing/Electronics
