Punch Tooling Upgraded for Extended Grind Life
December 1, 2009Comments
Wilson Tool, White Bear Lake, MN, has upgraded its High Performance (HP) line of punch-press tooling by including its new HP2 spring packs and by enhancing its WB tool steel. HP2 spring packs enable fast, accurate punch-length adjustment in 0.005-in. increments without the use of tools or buttons. And, the enhanced WB tool steel ensures maximum grind life of punches.
Wilson Tool Intl: 800/328-9646; www.wilsontool.com
See also: Impax Tooling Solutions, A Div. of Wilson Tool International
Technologies: Tooling
There are no comments posted. Tooling
Lou Kren Friday, August 25, 2023
Precision Tool Building via Precision Wire EDM
Brad Kuvin Monday, February 27, 2023
New Die Steel Reduces Wear on Form Details
