Pulsed GTA Welding Nets Big Productivity Gains
Big Gun Exhaust, Rancho Cucamonga, CA, a manufacturer of aftermarket exhaust pipes, has grown to become the third largest supplier in the ATV market. But such growth hasn’t come without challenges. Mike Young, owner of Big Gun and a championship motorcycle racer, began the company with the belief that he could outsource everything but the design of his product.
Challenges in Bringing Production Inhouse “Unfortunately, you can never get the product on time, pricing is never right and the quality isn’t what you want,” says Young, recalling his outsourcing experiences. “So in 2007 we decided to manufacture inhouse, and now we build our product the we really want to build it, so the quality is superior. We build every piece by hand.”
Now, with 13 employees, as well as three at a powder- and ceramic-coating facility next door, Big Gun sells to dealers around the world. While Big Gun is ramping up inhouse production, Young still sees the importance of slow and steady growth to achieve the highest-quality product.“We need to be kicking out 200 to 250 units a week, and that’s not enough to meet demand, but we’ve got to take gradual steps,” he says. “We still have to outsource to one other shop, but we finish the products here. We double-check everything and then package and ship.
Young credits use of the Dynasty 200 gas-tungsten-arc (GTA) welding machine from Miller Electric Mfg. Co., Appleton, WI, for helping the company approach its weekly goal of producing 250 performance pipes, made from 0.035-in.-thick Type 304 stainless-steel tubing. “The Dynasty got us up to 50 pipes per week right a,” he says, noting that further adjustments to the manufacturing process have allowed Big Gun to currently produce 150 units weekly.
Proper Fixturing a Must
“Fixturing is one of our most rigorous processes because the fixture replicates the exhaust system,” says Young. “It’s a tedious process but fruitful because we take the time. Our product is going to fit better than when we outsourced because now we have fixtures that match the whole pipe.”
Following the prototyping and fixturing process, the system is welded—very carefully.
You’ve got to be careful that you don’t distort it, because when the pipe gets hot, the materials move,” says Young. “The part has to fit into the fixture without a problem or it goes into the trash and we start over.”
Between these two steps, fitup and welding, the company has no room for error. Each fabricated pipe must be identical and perform in exactly the same manner.
Uniform Welding Pipe After Pipe
Pulse rate:
In terms of welding alone, the Dynasty helps Big Gun achieve uniformity because, among other things, operators have more heat-input control, according to Frank Sison, head of manufacturing at Big Gun.
“The crucial part of welding is not getting material hot to the point where it changes shape and doesn’t fit in the fixture,” says Sison. “With the Dynasty, I get a finer bead so the part stays cooler and doesn’t warp.”
Greater control is just one benefit of this advanced inverter-based power source, as the Dynasty has a state-of-the-art operator interface that offers a built-in pulser and more control of output parameters than a traditional GTA machine, according to Miller Electric officials. Prior to using the Dynasty 200 DX, Sison hadn’t worked with a pulsed welder, but he now appreciates pulsing for reducing heat input and adding arc stability. “I used to perform pulsed welding myself by hand,” says Sison. “The pulser is an ideal feature that, now, I don’t think I can work without.”
The ability to fine-tune output parameters saves Big Gun significant time.
“You get exactly the right-sized bead as you weld it,” says Sison. “And you don’t need to go over it and make it look pretty, because it’s pretty the first time.”
“Our welds look like they were performed by a robot, but are better because they are so flawless,” says Young, agreeing with Sison on bead appearance. “The fabrication is so clean, and everything has been deburred so well that it’s smooth, which is important because burrs can kill the power.”
Smooth Starts, Other Advantages to New WelderSison also notes the smooth starts associated with the GTA welding machine that assist in manufacturing gains at Big Gun.
“I can set the power supply on a lower amperage and actually work with it,” he says. “With our older machine, we could only go so low and the arc wouldn’t start. And when it did, it would blow a hole. You can actually finesse your start, and that’s what I really like about this machine.”
The Dynasty’s advanced inverter technology with Auto-Line power-management technology allows Big Gun to hookup to 120 to 460 V, single- or three-phase power with no manual linking, and reduces power draw.
“Our other machine sucked so much power out of this place,” says Young. “It was als popping breakers. Now we can run three machines at one time without any problem.”
At a rated output of 150 A, the Dynasty draws only 15.8 A of primary power. Compared to a conventional 250-A GTA welder, the Dynasty uses primary power four to five times more efficiently, according to Miller Electric officials. With such minimal amperage draw, Big Gun can plug in five of the welders for each conventional power supply. MF
Information for this article supplied by Miller Electric Manufacturing Co., Appleton, WI. Tel. 920/734-9821; www.millerwelds.com.
