Tooling Update
Compact Linear-Measurement Sensors
Monday, September 1, 2008
Pepperl+Fuchs, Twinsburg, OH, introduces PMI14V-F112-U-V3 inductive linear-measurement sensors, flush-mountable sensors 35 mm wide by 41 mm deep, with a 14-mm sensing range and resolution to 0.033 mm.
PMI14V sensors feature a voltage output with zero position adjust, giving users the flexibility to scale the units to shorter usable lengths to satisfy specific application requirements.
Pepperl+Fuchs: 330/486-0001;
See also: Pepperl+Fuchs, Inc.
