Corner Clips Improve Corrugated-Box Handling
August 1, 2008Comments
New and economical Corner Clip material-handling accessories from Creform Corp., Greer, SC, are manufactured from durable polystyrene plastic, providing long, repeatable use. The clips securely pin the end flaps of a cardboard box to its respective side. In most applications, only two clips, placed on opposite, diagonal corners, are enough to hold down
For added security and to bolster strength for stacking boxes, clips can be positioned at each of the four corners, helping to better distribute loads and prevent box sides from sagging. Clip configuration also allows for the use of plastic cable ties that, when installed diagonally across each clip, reinforce and brace the corners for heavy box-stacking applications.
Creform Corp.: 800/839-8823; www.creform.com
See also: Creform Corporation
