New Products
Simple, Intuitive Press Brake
Thursday, May 1, 2008
Simple, intuitive press brake
Bystronic Inc., Hauppauge, NY, introduces a new version of its mid-range press brake, the EP series. The brake comes equipped with independent Y1 and Y2 hydraulic piston control, and the Cybelec DNC 880 2D control can automatically select bend sequences. Programming on the EP is simple and intuitive for users. Designed for American-style tool integration, the press brake accommodates all types of punches and dies, with appropriate adapters. The EP features standard patented hydraulic crowning to deliver accurate bend angles across the entire length of the bed.
Bystronic Inc.: 631/231-1212;
See also: Bystronic Inc.
